:mad: another problem help
over the last few days when I have been driving my stereo turns off wipers don't work windows don't work heater fans stop (still displays temp) then after a while they all start working again .... Not good when it's lashing down with rain
Any one had similar issues and how can I solve this
Sounds exactly like when my alternator stopped working and electrical power was running low.
Maybe you should check if your alternator delivers enough power to your battery and/or your battery is about to give up.
When you disconnect the battery -ve. for a few minutes, also clean the connectors of any oxidization with a round file down to bright metal. A smear of vaseline or heavy grease is good on the lead battery terminal posts after scraping with a blunt knife, and will inhibit further oxidization by excluding the oxygen in the air from the metal.
Check all other heavy-current connexions to the battery, e.g. -ve ground connexion to chassis direct from battery; ground strap from engine to chassis both ends.
If any connexion in the heavy current starter circuit shows the slightest resistance, even as little as .1ohm, large glitch spikes from the starter motor can appear on the 12volt line to the microprocessors. This type of resistance is not normal, it has diode characteristics. If after all this you still get bouts of microprocessor madness, the battery may be going higher resistance than normal, allowing spikes from the alternator (sometimes called alternator "hash") to affect stored memories and stored instructions getting them partly garbaged, and leading to erratic control. Again, this 'chemical resistance' is not straightforward.
Leedsman.
Leedsman.
kevfils
May 9, 2014 01:57 AM
Jacob25crd
59
Oct 18, 2012 03:30 AM
rowl3y
Feb 27, 2011 10:20 AM
