Major Electrical Problems with 2008 T&C
Old Sep 10, 2013 | 03:23 PM
ecarter's Avatar
Default Major Electrical Problems with 2008 T&C
I have a 2008 T&C with some type of serious intermittent electrical problem. I will be driving down the road and the windshield wipers just turn on, all of the dash lights start flashing, all kinds of beeping and dinging bells go off and the radio turns on and off. The dealer looks at me like I'm crazy when I tell him this because, OF COURSE, it never does it when he test drives.
Now, looking over the internet, it seems like I'm not the only one. Here's a 3 minute You Tube video of a T&C that does exactly what mine is doing:
Anyone know what's causing this and how to get corrected?
Old Sep 10, 2013 | 10:48 PM
ID take a wild guess to a WINS module basically the ignition switch
Old Sep 12, 2013 | 02:47 PM
Raptor 07's Avatar
...that or the TIPM. That's also a guess.
Old Feb 2, 2014 | 09:35 PM
dlgg7's Avatar
Did you find what corrected it?
Old Feb 28, 2014 | 07:51 AM
williams1958's Avatar
Hi , did you ever find out what caused your problem? Regards Malcolm
Old Mar 1, 2014 | 11:53 AM
dlgg7's Avatar
Default Here's what I just found on mine
Can bus failure and fix on 2008 T&C
Old Mar 1, 2014 | 04:03 PM
Wooow....What a novel with a happy ending....Bet there's more of these Stow and Go's with that fault...
Old Mar 12, 2014 | 02:19 PM
845Rocks's Avatar
I had the same symptoms of the OP on my 05 TC. Bought used in 2009 w/52K miles. No speedo, most of the dash lights flashing and staying on. I was able to drive it to a dealer but warranty was not in the national base. I drove it home. Home dealer charged and Ok'ed the battery. Still had intermediate problems. Took back to dealer couldnt find any problem. They ok'ed the battery again. I finally replaced the battery and problem went away. To think the dealer was to cheap to replace the battery! My conclusion is that van uses a lot of electric and eats batteries.
Old Jan 14, 2017 | 11:28 AM
Olga Sanchez's Avatar
My 2008 t&c van does the same thing...I was thinking the battery but not sure. Did that resolve your issue?
Old Jan 14, 2017 | 02:44 PM
Go for a New Battery. But check charge of Alternator to make sure its charging right. Should be over 13.5v.
