memory disabled vehicle not in park ... HELP
Old Feb 18, 2015 | 10:06 AM
msd26129's Avatar
Default memory disabled vehicle not in park ... HELP
2005 grand voyager uk model <br/><br/>while im driving along my stereo turns itself down and i get a message on over head dispay(mpg info ect) saying "memory disabled , vehicle not in park" .. this has happened a few times over the last week
Old Feb 18, 2015 | 04:34 PM
msd26129's Avatar
Anyone with any info ?
Old Feb 19, 2015 | 03:17 AM
Leedsman's Avatar
Often a minor glitch (i.e. some stored data has been subtly garbaged by a spike on the 12volt line) in one of the micros. Cured if so by a hard reset, disconnecting the battery -ve for a minute or so.
Leedsman.
Old Feb 19, 2015 | 04:56 AM
msd26129's Avatar
HAVING LOTS OF PROBLEMS WITH GLITCHES ECT replaced to a new battery before xmas and i thought that had sorted it but they have all come back
1 cenral locking stops ( have to pull the fuse to reset the bcm
2 rear wiper sometimes works and sometimes dont
3 drivers heated seat sometimes works but mostly doesnt
and now this issue
all this points to the BCM think im going to have to bite the bullet and go to the steelers and see if they can update my BCM as i have heard this may cure some issues
Old Feb 19, 2015 | 06:29 AM
Vmaxxer's Avatar
I read about glitches like these when the connections under/to/from the fuse box are corroded.
maybe check that out?
Old Feb 19, 2015 | 07:48 AM
Leedsman's Avatar
DEFO. check for corroded contacts/connexions. Also check the engine/gearbox ground strap is good and tight at both ends. If not, the starter motor with its huge drain can put glitches on the 12volt rail when the micros are at their most vulnerable, i.e. the 12volt line dragged down to 9volt or so by the starter motor.
Leedsman.
Old Feb 19, 2015 | 05:08 PM
- crappy battery
- crappy IPM contacts
- crappy PCi / CAN BUS *
In that order, then look at the more difficult and expensive area's. Eliminate your battery being permanently on the edge, then the IPM in general, particularly underneath, then the computer BUS. I've no idea if you are CAN or PCi. I've never ever seen any error in the overhead display [#1]. All the problems in #4 could be any of the above but are likely to be the computer bus integrity itself or spikes from your alternator or voltage interfering with the BUS.
brianhaworth
Jan 10, 2014 09:53 PM
silverovum
Jun 20, 2013 03:52 AM
fe719
Feb 24, 2012 07:48 PM
Raborn
Nov 19, 2010 08:44 PM
Davidstingray
Mar 1, 2006 08:12 PM
