My Chrysler voyager has a fuel supply problem
Old Aug 2, 2009 | 10:17 AM
firebrad's Avatar
Default My Chrysler voyager has a fuel supply problem
I have an 1997 petrol Chrysler Voyager, it stopped working the other day, it has a spark from the plugs but I noticed the fuel pump wasnt working. I connected the pump directly to the battery and it worked, I dont have any power going to the fuel pump. I checked the fuel pump fuse and it is o.k. The fuel relay is working and the automatic shut off relay is working also. I'm getting a fault code 31 "purge solinoid open or shorted" I connected the solinoid directly to the battery and it works, there is no power going to the soilinoid either. Could the problem be either of the cam/crank relays or the oil pressure switch, if anyone can help me with this it would be much appreciated. thanks in advance.....
Old Aug 7, 2009 | 09:20 PM
jazfe's Avatar
Default no start
When you jumpered the fuel pump did the engine start? As for the oil pressure switch, if the oil light is not on the I would think it is ok.
woodfielder
Cirrus & Breeze
Feb 3, 2012 11:03 PM
jimmy154
Jul 28, 2010 09:18 PM
Tobbe_gbg
Jan 6, 2010 01:24 PM
trev0006
Nov 17, 2007 08:34 AM
mack324
May 23, 2007 02:47 AM
