MyGig - Flash Drive Size
Old Mar 5, 2008 | 09:12 AM
jostclan's Avatar
Default MyGig - Flash Drive Size
when I purchased my 08 T&T Touring, I uploaded a bunch of my music via the USB drive port. My flash drive is a 1GB model and it takes way too long for this task. As I have a ot of music, I am thinking about buying either an 8Gb or a 16GB flash drive to handle the uploads.
My question is, has anyone used a larger flash drive (8GB or 16GB) on your system and had any issues with drive recognition or file loads?
Old Mar 5, 2008 | 10:48 PM
Loki Sunrider's Avatar
Default RE: MyGig - Flash Drive Size
Yes! I just purchased an OCZ ATV 16GB USB Flash Stick from Amazon.com for $67 dollars after a $10 mail in rebate.
I loaded a total of 15GB of music files on the stick and it took 2hrs. 10 min. to upload all of it onto the MyGig hard drive.
I then deleted all the music off the MyGig hard drive and that only took about 7 min. to do.
Just make sure you have your albums saved as folders and don't put folders into upper level folders or MyGig will
have trouble with it. Just use one level folders for your music.
And make sure your digital pictures are stored at the main root level directory of the USB flash stick. Don't put them
in a folder and drag that onto your USB stick. Make sure you crop and or resize your pictures down to 240 x 158 pixels.
Thanks and see you out there,
Loki Sunrider
thorze
Nov 11, 2023 11:01 AM
jtocwru
Sep 19, 2022 06:14 AM
CharlieHigh
Nov 21, 2017 06:21 PM
ohboyseth09
Apr 9, 2010 11:48 PM
Loki Sunrider
Feb 29, 2008 10:36 PM
