Need help with jumping speedometer
Old Jan 28, 2016 | 08:37 PM
Eddie c's Avatar
Angry Need help with jumping speedometer
Hello I have an 02 town and country 3.8 motor the other day the speedometer started jumping then the transmission started acting up. I did some research and found that the usual problem is the speed sensor. so I changed both speed sensors. now the transmission is acting fine but the speedometer is still jumpin when in gear and not moving..if you give it gas and start to move the jumping stops. but if you stop at a red light it starts back what else could it be... I have already recalibrated the instrument cluster too thankyou how any hintson other things to check!
Old Jan 30, 2016 | 06:09 AM
Sound hellafa like you have an earthing cable there as when you are moving vibs and airflow raise cable from body/trans. A just incase senario...
Old Jan 31, 2016 | 12:10 AM
Eddie c's Avatar
can you explain that a little more plz
Old Jan 31, 2016 | 09:04 AM
Vonhofinvule's Avatar
I agree sound like you have a ground issue. I had something very similar happening with my 98. However, what worked for me was to put a new ground lead from the engine to the battery!
Old Jan 31, 2016 | 02:11 PM
Yeh check all the cables around your auto box and exhaust pipe area for grounding.
Old Feb 5, 2016 | 07:57 PM
Eddie c's Avatar
auto box?
Old Feb 6, 2016 | 07:11 AM
dieselvoyager's Avatar
have one with nearly same problem "not solved yet" . But it's only the speedo. Not any problems with the transmission. Looking forw. to hear out come !
Hotstuff21
Jan 30, 2016 06:04 AM
almangar
Sep 22, 2012 06:59 AM
Confidance
Apr 23, 2012 08:40 AM
steviemac74
Nov 25, 2011 04:04 AM
goat1966
Dec 8, 2007 02:55 PM
