Need help to replace clutch
Old Jan 9, 2010 | 05:43 PM
clinton's Avatar
Default Need help to replace clutch
Lyon FRANCE
I have a 1991 Chrysler Voyager with a 2.5 petrol engine and 5 speed manual transmission.
The clutch & pressure plate need replacing.
If anyone has a workshop manual for this model can they please email me the section showing an exploded view of the clutch.
Many thanks
Old Jan 9, 2010 | 06:04 PM
22chrysler's Avatar
This job is very straight forward. I have step by step proceedures in a shop manual but no way to post it and I'm not about to take the time to write it all out. I suggest you just get a shop manual so you have all critical information and torque specifications.
In summary:
disconnect battery
remove starter
remove axle shafts
disconnect clutch and shifter cables
remove transmission mount and stabilizer strut on back of transmission
remove bellhousing bolts
remove the transmission
to install, reverse disassembly proceedures
The exploded view of the clutch is basically the exact same as any other vehicle clutch assembly..
Old Jan 10, 2010 | 03:39 PM
clinton's Avatar
Thank you for your reply.
HittOD
May 26, 2014 11:02 PM
ejoffe
Jan 11, 2012 08:35 AM
skullo
Feb 28, 2011 02:03 PM
stevelor4
9
Mar 26, 2010 04:48 AM
malegebi
Dec 17, 2009 01:57 PM
