No air comes out from the rear a/c outlets
Old Sep 5, 2007 | 11:41 PM
jimzhang02's Avatar
Default No air comes out from the rear a/c outlets
I just bought a 2002 Town & Country and found out no air comes out from the rear a/c outlets at all. It is a three zone climate control. The front side works perfectly. I checked the rear blower fuse. It is OK. I swapped the front blower relay and rear blower relay. The cold air comes out from the front a/c outlets but no air out from the rear outlet again. It seems the blower is not working. What should i try next? The rear blower power module or the blower motor? It will be a big job to access these components. Any input is appreciated. Thanks.
[align=left] [/align]
Old Sep 6, 2007 | 07:52 AM
Default RE: No air comes out from the rear a/c outlets
are u trying to use the rear controls orthe ones up front?
Old Sep 6, 2007 | 11:18 PM
jimzhang02's Avatar
I tried to set front setting to auto then change the temperature. Also I tried to set front setting to rear control and turned the rear control **** different postions. Neither way worked.
Old Sep 7, 2007 | 09:07 AM
u might be looking at a rear blower motor power module.
Old Sep 7, 2007 | 11:17 AM
jimzhang02's Avatar
Thanks for the suggestion. I have to remove the right quarter trim inner panel to access the rear power module, right? Do I need a special tool to pry the plastic panel out (to disengage the hidden clips)? What other tools do I need to complete this job. Thanks a lot.
Old Sep 7, 2007 | 05:14 PM
I use a trim clip remover but u can use a screw driver and just reattach them back to the panel once removed.
Old Sep 8, 2007 | 11:01 AM
JusGene's Avatar
Default Similar thing on my '97
but with the heat.
When I use A/C up front, the rear vent operate to recirculate the car air. When I switch the front control to heat (with a/c button lit/on) air flow from the rear vents stop.
Gene
Old Sep 10, 2007 | 01:13 PM
jimzhang02's Avatar
Thanks a lot.
Old Oct 9, 2007 | 01:56 PM
jimzhang02's Avatar
A update: The problem was solved by replacing the rear blower motor power module ($65.50 part#04885482AA). Now the cool air comes out from the rear a/c outlets.
Thanks for the help.
Old Oct 10, 2007 | 06:48 PM
Farva's Avatar
The reason why no heat is coming from the top vents is because when heat is selected for the rear they come out of the bottom vents and use the principle of heat rising. Anyway that is why you do not get heat from the top vents.
-Farva
kelcan72
Dec 26, 2012 10:06 AM
wire.nut
Jun 26, 2011 07:39 PM
harrym
May 11, 2011 07:08 PM
471Magnum
Jan 28, 2010 12:49 AM
Sierrasan
Mar 23, 2008 11:41 PM
