no cold air from front panel when the vehicle stops
Old Feb 3, 2008 | 06:05 AM
20asd's Avatar
Default no cold air from front panel when the vehicle stops
03 Voyager Limited AWD ( had it only a few months )
Hi, need expert advice on this pressing issue. When the a/c is on and the vehicle is slowing to a stop,cold air stops blowing out from the front panels ( the 2 x rear outlets are otherwise working fine when the vehicle is at a stop ). When the vehicle starts moving again, cold air starts blowing again from the front panels !!! Any suggestion?
Thanks & regards.
Old Feb 3, 2008 | 08:13 AM
Default RE: no cold air from front panel when the vehicle stops
u have low freeon and more then likely a leak some where.
Old Feb 3, 2008 | 06:34 PM
20asd's Avatar
hi, do you mean refrigerant - the gas used in the aircon?
regards.
Old Feb 3, 2008 | 06:56 PM
yes freon is what is used 134a
Old Feb 3, 2008 | 07:18 PM
20asd's Avatar
hi, i would have thought air would still be blowing out of the front panels whether the freon is low or not . In my case, air (whether warm or cold ) just stop blowing out of the front panels, it is like the blower stops blowing !
regards.
Old Feb 3, 2008 | 09:18 PM
U did not say that U said this (cold air stops blowing out from the front panels) so what is the real issue then???
Old Feb 3, 2008 | 09:32 PM
20asd's Avatar
ok, let me rephrase the problem.
With the air con on and the vehicle moving, cold air is blowing out of ALL outlets ( fonrt panels AND the 2 rear outlets ). But when the vehicle is slowing to a STOP, there is no more AIR blowing out of the front panels ( the 2 rear outlets are still blowing cold air while the vehicle is at a stop ). In other words, the front blowers stop blowing anything when the vehicle is not in motion !!. The front blowers start blowing cold air again when the vehicle is in motion.
regards.
Old Feb 3, 2008 | 10:41 PM
thats better but what U are saying is has nothing to do with one another. turn the fan on high does the blower motor turn on if yes u need a blower motor resistor
Old Feb 3, 2008 | 10:57 PM
20asd's Avatar
"turn the fan on high does the blower motor turn on if yes u need a blower motor resistor"
no,
regards.
Old Feb 4, 2008 | 01:38 PM
I wonder's Avatar
first thing to do:
go to the service, let them check the pressure of the system. if there is not enough refridgerant in the system, there is no cooling.
