no cold air from front panel when the vehicle stops
Old Feb 4, 2008 | 06:28 PM
20asd's Avatar
Default RE: no cold air from front panel when the vehicle stops
i tend to agree with "CHRYSLER TECH" that the issue is with the fan/blower. It is just that the fan/blower stops blowing air (whether cold, warm or hot) when the vehicle is STATIONARY. But as soon as the vehicle is in motion again, the fan/blower starts blowing air out again.
regards.
Old Feb 4, 2008 | 07:24 PM
moe's Avatar
moe
how does the blower know when the car has stopped? maybe its a vacuum related issue?
Old Feb 4, 2008 | 07:48 PM
THERE IS NO VAC IN THE DOORS ANY MORE MOR ALL ELECTRICAL as for when it shops there is no fan speed i think we are missing something here as I said be the van and fan speed will have no relation to one another.
Old Feb 4, 2008 | 08:25 PM
20asd's Avatar
sounds scary, what could be missing ? has it got to do with system settings?
regards
Old Feb 5, 2008 | 12:25 PM
  #15
I wonder's Avatar
am I speaking chinese?
the only thing that connects these things is engine revs. when at idle, compressor does not provide enough pressure, thus no air con.
try one simple thing. stop the car, put it in neutral and keep the revs above 2 000. see if cold air is going out of the vents.
if it does, you dont have enough refridgerator gas in AC system. refill in service.
if you get warm air from vents then, it's something else.
Old Feb 5, 2008 | 12:45 PM
  #16
moe's Avatar
moe
this is a good one. can't wait to see it unfold.in eitherenglish or chinese. lol!sorry i wonder
Old Feb 5, 2008 | 01:00 PM
  #17
I wonder's Avatar
no problem, moe.
i am just giving a simpliest possible solution becouse it it one of the first things to check.
over the time, gas escapes through hoses and pipes, there is not enough of it in the system and compressor can not achieve sufficiant pressure.
when you drive, compressor works faster and you have some cold air.
it is easy to check. any A/C service has pressure gauge to check system. if the pressure is low, they refill the gas. operation is cheap and fast.
much cheaper then looking through the car for malfunction.
it's like checking if you have power at all, if your TV set suddenly shuts down.
Old Feb 5, 2008 | 02:16 PM
  #18
I wonder go re read what was posted this is not a hot or cold issue this is as quoted the air will stop blowing if the van comes to a stop. To moe and I this is well a first to me.
Old Feb 6, 2008 | 05:27 AM
  #19
I wonder's Avatar
I understood that the blower is still sending some air into the car, but it's not cold.
I'm thinking;
-air speed itself is not enough to push air into the car.
-if the blower is not working, air-con wouldn't start anyway. so it MUST be that AC is working, but insufficiently.
-he still gets cold air in the back.
I was confused about AC working in the rear, becouse I don't know if the van has two separate AC systems. but the story about dead blower does not stand.
Old Feb 6, 2008 | 11:35 AM
  #20
moe's Avatar
moe
is it no air movement at at at idle.? or temp change?
