Noob says hi
Hello everybody,
Just registered and posting to say hello.
As the most fertile man in Ireland I threw my trousers on the bed and ended up with a fourth child resulting in the purchase of a 2004 2.8auto CRD Grand Voyager.
Before buying it I did a lot of reading and opinion on the Voyager seemed very polarised between "this is the greatest car I've ever bought" to "this is a heap and it's broken my heart"
So from everything working 6 months ago the list of items to be replaced is:-
front discs and pads
front suspension has developed a quite noticeable "klonk" at the merest change in road surface
rear parking brake shoes are down to metal. looks like somebody has driven with the handbrake on. Took the disc off and the springs fell out as they'd rusted through, and the back plates are rotten.
4 tyres
But apart from the above whinge, this what I'd like to know about.
One of the kids left the lights on the dvd player on and flattened the battery.
So after I charged up the battery and got it going again, I noticed that the temp gauge never moved above 1/4 and even on the hottest setting the air never got warm.
I heard there is a reset function - with the battery being drained could this be the cause or is something more sinister happening.
(The cooling system is full even if the water is a bit brown looking)
Sorry about the whinge on my first post, but I'm sure there'll be plenty more.
Thanks,
pob
4 tyres
Thanks,
pob
It was very satisfying to take it for a drive afterwards and have no more clunk sound though. Well worth the effort.
A bit more info on the bushings and links: http://www.ricksfreeautorepairadvice...nks-and-thumps
Your heat problem sounds like a classic stuck open thermostat. Try tapping on the housing to get it to close. In any case, it's time for a new one. A perfect opportunity to flush and replace that brown coolant too. If the gauge was reading correctly but you had low heat then I could say maybe the battery drain effected the HVAC control module. The combination of low heat output and low heat indication scream thermostat. A coincidence? Blame it on the celtic gods. Maybe Aine of Knockaine. She could be effecting your trouser issue too: http://www.angelfire.com/wizard/celticdeities/
Don't think Aine's to blame this time - more like a classic case of Murphy's Law.
Hi Pob and welcome.
It does sound like your thermostat needs replacing. I'll not say too much about it as there is a lot of information written on this forum about, do a search and you'll see what I mean. But I will say that it will cost you alot more than you think (at least £70 for the part) and it will be much more difficult to replace than you think. (its around the back of the engine)
My 2004 Voyager clunks like yours over bumps. I think my sway bar links are ok, but I can visibily see the roll bar bushes are quite badly worn. I've been living with it for quite a while now, but will probably replace them when the weather gets a bit warmer.
Yes - I know what you mean, the MOT isn't until June so I'll wait until then. The voyager doesn't fit in my garage and I don't fancy changing anything in the dark and the cold on the driveway.
I was looking on ebay and the only one I could find was £136 !!
But the wife informs me that the fairies came and fixed it today as the temp came up to normal and the heating was fine - hopefully this was an one off and not the beginning of an imminent failure.
Thanks for the replies.
136! Are you kidding me? That's about $80 US. If you pay more than $20 in the US you're getting ripped off. Are you sure you're looking at the right part? Ah. Maybe you have a diesel. Might explain it.
It's for the diesel, it's sealed in a housing, it would be too simple if the thermostat housing just bolted off the engine.
THERMOSTAT CHRYSLER VOYAGER 2002-2006 2.5 & 2.8 CRD | eBay
There were cheaper ones, but they were posted from Latvia.
The Voyager diesel thermostats can only be serviced by replacing the whole housing. Those units from Latvia are actually the exact part that Chrysler sell for twice the price so are definately worth looking at.
Hopefully your thermostat will last a bit longer, but it could well be the first signs of it failing.
