Not happy with my T&C
Old May 16, 2012 | 08:20 AM
janer's Avatar
Default Not happy with my T&C
I recently purchased a used 2010 T&C, gorgeous van and everything seemed fine, until,
Suddenly I lost power, steering was very difficult but I managed to pull over. Turned off and then restarted and all was fine. This happened 3 times in a half hr. period. Luckily I was on a country road and not the 401.
Went straight to my mechanic. He spent 3 hrs with the computer and could find nothing.
The only suggestion was moisture in the gas OR my key fob is not connecting with the sensor and is shutting off the engine.
Anybody else having this problem?
When I turn my key to start, there is no clicking as it passes acc., on, and then to start. My mechanics truck makes a click every time you pass acc., or on. Is this normal or does your ket not click either.?
Any advise, before I trade it in!!!
Old May 16, 2012 | 09:58 AM
oldmansvan's Avatar
you are comparing apple and orange. Your mechanics truck is NOT a 2010 T&C so forget about that.
You suddenly lost power probably has nothing to do with how you turn the key. If that's my van, I would take it to the dealer and have them check it out. I don't think is the key fob becaue all it does is let you start the car. Once it started, you don't need it to keep the car running.
hope you still have the car under warranty. But as you say if the car is gorgeous and fine why "trade it in" just for this little thing? Even a new car will have problem anyway...
Old May 16, 2012 | 10:52 AM
TNtech's Avatar
Your mechanic's truck, eh? Did your "mechanic" use his truck as a reference and push you into an incorrect assumption?
Old May 16, 2012 | 04:56 PM
Raptor 07's Avatar
Could this recall apply? Might check with your local dealership: Chrysler Recalls Nearly 250,000 Vehicles for Engine Stalling - U.S. News Rankings and Reviews
Old May 16, 2012 | 06:18 PM
janer's Avatar
Yes, I am going to the dealer on Fri. The key fob connects to the sensor in the ignition thereby telling the engine to start. If you take it out of the ignition the engine turns off.
I don't consider loosing power and steering to be a little thing. Good thing I was on country roads and could guide it over to the shoulder. If I had
been on the 401 in the passing lane and the engine stalled, I would be road kill by now.
No, I don't think the mechanic pushed his opinion on me. In a little village like ours, your reputation is everything and if you do not give good service to your customers, they will go elsewhere.
I am going to call Chrysler as well as visit the nearby dealer, as this recall may be applicable. Since I bought the van only 8 months ago, the previous owner may have ignored it.
Thanks for posting this link. Very good info.
Old May 16, 2012 | 08:38 PM
TNtech's Avatar
The recall is for the key fob kicking back to the off position. Post the last 8 of your VIN and I can tell you what's been done.
Old May 17, 2012 | 07:23 AM
janer's Avatar
Default Vin
last 8 nos AR126439
thanks, i appreciate your help.
Old May 17, 2012 | 12:09 PM
TNtech's Avatar
L25 recall was done sept 2011 @ 40,530 KM. That doesn't mean the WIN module is not at fault though. When you say losing power, you mean everything goes dark, or is it just the engine that dies?
Old May 17, 2012 | 05:59 PM
janer's Avatar
Hi: the engine dies and steering is very difficult. No lights come on the dash, no warning at all.
Speedometer drops, hard to steer. Each time, I pulled over, turned the engine off and restarted. It ran fine.
Each time this happened I was on an incline, twice while driving, once when stopped at a light.
Funny that the recall was done Sept.2011, as I bought it 28th Aug. 2011 and it first went to our mechanic, mid Oct. for its winter check up.
I never received any notice for THIS recall.
I did receive a notice re brake problems, extending the warranty to 2 yrs. or 40K.
I had them replaced at my mechanics in Oct.,when he noticed excesive wear, but was not eligible for the warranty as I had 40.888K on the clock.
Hope this helps with your diagnosis.
Old May 17, 2012 | 06:01 PM
janer's Avatar
p.s., when I bought it it had 40,300K on the odometer.
Can you tell me where this Sept. recall/work was done.?
I purchased the car in Lindsay Ont. Canada Aug.28/2011
