OBDII Check Engine Light Fault Code Tips
Old Feb 23, 2014 | 04:17 PM
Munro's Avatar
Hey AlanC, I hooked up to the parallel printer port on the Spitfire and the diagnosis went something like: check for spark; check for fuel; check for compression; engine should run - else replace the flux capacitor and jump start with 1.21 Gigawatts. Time warped.
Old Feb 24, 2014 | 01:13 PM
Hey Munro, you might get better results using the flux capacitior from a GT6. From 1973 Triumph used a low energy flux capacitor in the GT6 that only used 0.83 Gigawatts. Apart from improving the boot-up procedure, it also enabled the Spitfire to play true quadraphonic 8 track cartridges through it's surround sound speaker system. I was a TR5 man myself so I do know a lot about these things
mwestpacifica
May 3, 2012 09:11 PM
stewartsoftware
Apr 17, 2011 03:22 PM
jcthelight
Mar 10, 2010 10:56 PM
Lorin
Mar 6, 2010 10:12 AM
Adriana115
Nov 1, 2008 02:07 AM
