oil light stays on
Old Mar 28, 2014 | 08:34 PM
jentsiepak's Avatar
Default oil light stays on
oil light comes on after engine warms up and when I hit the brake, then goes off. Just changed oil and filter. Any suggestions on what it could be. On a 2000 Chrysler Grand Voyager SE
Old Mar 28, 2014 | 09:48 PM
Raptor 07's Avatar
Either your oil pressure is actually low or the oil pressure sender is bad. Odds are it's the later. On the 3.8 and 3.3 engines it's just to the left of the oil filter. I would change that first because they are cheap and fix these most of the time. If that doesn't fix it connect an oil pressure gauge (loaned from Autozone etc) to verify the actual pressure. If you verify it's low you have a bad pump or an obstruction.
If you haven't changed the oil regularly, you could have sludge built up in the pan that's floating and blocking the oil pick up. May have to remove the oil pan and inspect.
Old Mar 29, 2014 | 03:42 PM
Your words actually point to low oil in sump...Oil becomes more fluid when hot.....Brake, oil surges to front of sump, pickup is exposed and oil light comes on...Brake off, oil levels in sump, pickup collects oil and light goes out...
Old Mar 30, 2014 | 03:18 PM
Stutz2 back a few years ago cured oil light with a new switch sender.
Old Apr 1, 2014 | 03:03 PM
pete@co.uk's Avatar
I had the same problem on my old w reg 2000 grand voyager 3.3 the oil light kept coming on and the chime sounded every-time it came on i was thinking oil pump causing low oil pressure or something worse the oil was new and it wasn't low it turned out to be the oil switch was bad changed it and all was ok hopefully its the same with yours ......
02Voyager
16
Jun 26, 2013 02:22 AM
kingkohlmn
Dec 28, 2009 09:07 AM
skidip1
9
Aug 5, 2009 08:06 AM
rblanken
Nov 6, 2008 09:44 PM
VsAspen
Oct 13, 2008 11:57 AM
