Oil pan bolt torque setting for 2001 3.8L
Old Mar 24, 2008 | 04:07 PM
tntandc's Avatar
Default Oil pan bolt torque setting for 2001 3.8L
Have a leaking gasket on oil pan after only 37k since replacement by dealer (102k current mileage). Want to try tightening bolts before spending money again.
Old Mar 24, 2008 | 04:48 PM
Default RE: Oil pan bolt torque setting for 2001 3.8L
INSTALLATION [ol][*]Clean sealing surfaces and apply a 1/8 inch bead of Mopar® Engine RTV GEN II at the parting line of the chain case cover and the rear seal retainer (Oil Pan Sealing).[*]Position a new pan gasket on oil pan (OIL PAN).[*]Install oil pan and tighten fasteners to 12 N·m (105 in. lbs.) (OIL PAN).[*]Install cover to transaxle case (Powertrain Struts and Transaxle Case Cover).[*]Install the strut bolt to transaxle housing (Powertrain Struts and Transaxle Case Cover). Tighten all bending brace bolts.[*]Install the drive belt splash shield.[*]Lower vehicle and install oil dipstick.[*]Connect negative cable to battery.[*]Fill crankcase with oil to proper level.[/ol]
Old Mar 25, 2008 | 08:38 PM
tntandc's Avatar
Thanks for quick response. Will check bolts with torque wrench and see what happens.
taug14
Aug 4, 2012 12:47 PM
tmizzle
Mar 6, 2012 07:17 AM
Liam548
Jun 13, 2010 07:32 AM
jetek2588
Sep 5, 2009 04:51 PM
billbon8
Oct 1, 2008 07:57 AM
