Oil Pan Continual Leak at seal
Old May 3, 2017 | 10:21 PM
Vikingtu's Avatar
Default Oil Pan Continual Leak at seal
I have a 2000 Town and Country with a 3.8L engine. I have changed that oil pan gadget twice and it still leaks. I used a fel pro gasket and followed the direction to the T! I even called Fel Pro before installing the second gasket and they suggested using a small amount of RTV black at the casting seems. All torqued to specs! Does anyone have any suggestions on how to get this thing in right. I am considering using RTV or Right Stuff on the Fel Pro gasket. It's not like I haven't done this before as I put in a new gasket in my 2000 Dodge Caravan. Any help or suggestions would be appreciated.
Old May 4, 2017 | 09:33 PM
Where it is leaking at what part?
Old May 4, 2017 | 10:04 PM
Vikingtu's Avatar
Hi KKeller, Thank you for your reply. The oil pan is leaking where the gasket meets the block at various locations. I used the fel pro gasket and followed the directions and as I mentioned I even called the company after the first gasket failed. They mentioned using a small amount of RTV in the area where the block casting (where parts of the block are mated) which I did use. The pan is not warped or dented. Not sure what to do next. I changed my gasket on my Dodge Caravan (same year) with no problem. I thought about using Right Stuff ??? Any help would be appreciated. Thanks!
Old May 5, 2017 | 11:43 PM
Get this and use around the gasket both sides
Amazon Amazon
Old May 6, 2017 | 12:26 AM
Vikingtu's Avatar
Thanks! I will not be able to do the job for a few weeks but I will keep you posted. Thanks for the advice.
george3405
Dec 20, 2015 09:12 PM
97_chrysler_lhs
9
Mar 26, 2013 06:12 PM
milesy_boy
11
Nov 19, 2009 05:34 PM
sebringted48
Jan 29, 2009 05:41 PM
jdman1
Feb 28, 2006 06:12 PM
