oil rocker supply
Old May 19, 2007 | 04:39 AM
mack324's Avatar
Default oil rocker supply
hi all
where does the rocker supply hole on diagram goto in the block
i need an exact diagram if anyone has one...or a good discription of oil travel from the hole, as i have blockage before this hole......my hydraulic valves are ok as oil is coming out of them but not getting to rocker shaft....
thanks all
[IMG]local://upfiles/3137/13D4012EECA74F74BFBE94676117E279.jpg[/IMG]
Old May 19, 2007 | 07:16 AM
Default RE: oil rocker supply
year and engine size
Old May 19, 2007 | 12:40 PM
mack324's Avatar
sorry ......1997 3.3 litre
thanks
Old May 22, 2007 | 02:13 AM
mack324's Avatar
hold it a minute.....diagram
11 years + experience and you cant tell engine difference..
Old May 22, 2007 | 12:44 PM
ll that pic showed was a v 6 engine now if u can tell me what it was just be looking at it then more power to ya. There are 3.3 and 3.8 engines bascily the same. same block, bore different,heads some what the same. SO sorry if i dont want to give u the correct info with asking what engine and year u have. Oh and if u had a 2003 mini van with a 3.8 that is a different engine build all together.
[IMG]local://upfiles/1033/DF9CBF02B11E4C0E936703014E16E11F.gif[/IMG]
Old May 23, 2007 | 02:47 AM
mack324's Avatar
so sorry
thanks for reply
got same diagrams.........found out where they go
3 gallery holes in triangle (see picture)
These go to all the oil feeds
so i took out the gallery plug at the bottom and jetted water in until i saw it imerge from all the oil holes including the rocker shaft feeds
hopefully this has cured the problem, just waiting for delivery gallery plug and cam chain
[IMG]local://upfiles/3137/EB6394D067C74786BCA7C502F5A51B54.jpg[/IMG]
Tobbe_gbg
Jan 6, 2010 01:24 PM
firebrad
Aug 7, 2009 09:20 PM
trev0006
Nov 17, 2007 08:34 AM
laszlo
Apr 24, 2007 08:04 PM
BLUENEWPORT
Jan 10, 2007 03:45 PM
