Position Coolant Temperatur Sensor?
Old Apr 15, 2017 | 05:39 AM
torgersoe's Avatar
Default Position Coolant Temperatur Sensor?
Hi,
i'm a german driver of a 2014 Town & Country. I drive a lot of long Distances, and this car is perfekt.
Now i have a Problem:
The Radiator Fan dos`nt work. How can i fix the Problem?
kind regards from Germany
Uwe
Sorry for my broken English.
Old Apr 18, 2017 | 01:16 AM
the fans do not work off the coolant temp sensor the sensor tells the PCM what the temp is and then the PCM will turn the fans on based off logic.
Old Apr 19, 2017 | 11:11 AM
Does the temperature gauge reach 'normal' after driving a few kilometers or does it usually display 'cool'. If the engine never reaches 'normal' temperature then perhaps the problem is with the thermostat. Plenty of posts on this forum about faulty thermostats.
Old Apr 20, 2017 | 02:03 PM
torgersoe's Avatar
Thank you for your Information. now i understand, how it works..
Uwe
Old Apr 20, 2017 | 02:11 PM
torgersoe's Avatar
Yes, the gauge reach "normal". I think the Thermostat is not that Problem!
Where is the Fan-Relais Position? I will check it.
Regards
Uwe
Old Apr 24, 2017 | 10:46 PM
d1940u's Avatar
Mine on a 2013 are located top of radiator,driver side. The two are mounted on a thin metal bracket.
sumncguy
Apr 17, 2012 07:27 AM
t_bell40
Aug 6, 2008 07:44 AM
96RedLXI
Jul 19, 2008 08:38 AM
jjmenard
Sep 6, 2007 05:33 PM
mr.belvedere1954
Jul 29, 2007 03:16 PM
