Possible CV shaft replacement?
Old Sep 30, 2017 | 07:08 PM
ProfitOfDoom's Avatar
Default Possible CV shaft replacement?
My wifes 2010 Town and country has a developed this noise,,sounds like its coming from the front passenger side wheel. We had the wheel bearing replaced about a year ago,So we thought it might be the tire as they are not the greatest. I rotated the wheels from front to the back and took it for a drive and the problem was still there. So I jacked it up and put it in neutral and spun the wheel around,,didnt feel any grinding or rubbing,,no side to side wiggle in the tire so I assume the wheel bearing is fine. Dont feel any wobble or pulsing in the pedal when braking,So I assume the rotor and brakes are fine.
So I check the cv shaft,the boot isnt torn or any visible sign of a problem,,Dont really get a up down movement but when I tug on it in and out I get some play,,Not very much but it does move slightly. So I went to the driverside to compare it and that shaft didnt move at all,,So these shafts should have Zero slack and this is most likely my problem? I also notice the drivers side has a rubber dampner around the shaft in the middle and the passenger doesnt have one,,This normal?
What do you think?
Old Oct 1, 2017 | 08:38 AM
REBEL59's Avatar
Darn NOISES!..
While driving, if you make gentle left or right turns(like doing a sudden lane change maneuver) does the noise go away until you straighten back out? That would indicate a bad wheel bearing on the side that is "unloaded".
davet
Apr 1, 2010 11:44 PM
deerunsop
Oct 13, 2009 08:05 PM
cvchrysler
Jan 3, 2009 08:56 PM
3.3lxbluevan
Jul 7, 2008 09:39 PM
coreaper
Feb 11, 2008 10:25 AM
