Power sliding door a different problem now !
Old Feb 25, 2011 | 08:07 AM
stewartsoftware's Avatar
Default Power sliding door a different problem now !
I know I will have to change the power latch on the sliding door as it does the classic pop to unlock and nothing else !, although most of the time it closes under its on power, but today when it is closing to gets almost to the end and just stops !, leaves a small gap and does this 9 times out of 10 !.
Is this still connected with the power latch or is it another problem ?.
Many Thanks.
Old Feb 25, 2011 | 09:29 AM
look at the wires in the black loom see if U have a broken wire in there
Old Feb 25, 2011 | 01:59 PM
Had a look today in the plastic chain type loop, seemed okay and the black wire is tight, it always stops in the same position about 3 inch from closing, could this be a wire or the latch.
It also makes a much stronger 'Ping' noise when it unlatches (But then does not move under its own power) than it ever done before.
Thanks.
drob181
Aug 15, 2014 02:58 PM
dakrt360a
Oct 4, 2013 11:32 AM
Huslayer
Jan 28, 2013 10:14 AM
stewartsoftware
Feb 27, 2011 03:54 PM
curiousgeorge
9
Dec 23, 2010 06:01 PM
