Program Key - 2013 T&C with Push to Start
Old Nov 16, 2015 | 10:24 AM
stubarnes4141's Avatar
Default Program Key - 2013 T&C with Push to Start
I purchased a 2013 Touring L with push to start. The vehicle only has 1 key fob. I have seen how to program a new key, however it requires placing it in the ignition. Being that this is push to start, there is no ignition. Is a trip to the dealer my only option?
Thanks.
Old Nov 16, 2015 | 02:15 PM
ChryslerCACares's Avatar
Thanks.
Stubarnes4141:
Key Fob duplication may be performed at an authorized dealer, this procedure consists of programming a blank Key Fob to the vehicle electronics.
Please contact an FCA dealership to have this done.
Thank you.
Kathleen
Top Care Specialist
FCA Canada
Old Nov 16, 2015 | 07:46 PM
georgef's Avatar
Unfortunately you can't program a new fob yourself for the 2013's, you will need to go to a dealer or find a locksmith that is capable of programming these fobs.
Also be aware that the start button is removable, if the battery in the fob dies you need to remove the button and use the fob in ignition switch.
The following quote is from the 2013 Users Guide:
• In case the Key Fob battery is dead, use the emergency key to open the door. If the vehicle is equipped with Keyless Enter-N-Go™, remove the ENGINE START/STOP button by inserting the metal part of the emergency key under the chrome bezel at the 6 o’clock position and gently pry the button loose.
NOTE:
The ENGINE START/STOP button should only be removed or inserted with the ignition in the LOCK position (OFF position for Keyless Enter-N-Go™).
• With the ENGINE START/STOP button removed, start the vehicle by inserting the Key Fob in the ignition and turning to the Start position.
Old Nov 20, 2015 | 07:43 AM
Thank you for this information! The dealership wasn't very helpful going over the features. I purchased used from a Ford dealer....oh well the price was great.
Old Nov 20, 2015 | 07:54 PM
georgef's Avatar
If you don't have the Users Guide and Owners Manual you can download them at this link: Owners & Service Manuals - Chrysler - Cars & Minivans
monsterdub
May 5, 2024 11:10 AM
Accelenut
May 16, 2013 11:58 PM
james-jt
Jun 15, 2012 08:16 AM
AgEnT
May 13, 2008 08:22 AM
AgEnT
Dec 17, 2006 08:34 PM
