Radiator Fan Ralay on Chrysler Grand Voyager 3.3l Yr2000
Old Apr 9, 2014 | 02:35 AM
Huggy59's Avatar
Default Radiator Fan Ralay on Chrysler Grand Voyager 3.3l Yr2000
Hi all the experts out there!
Earlier on I had a problem on both my cooling and radiator fans which was not functioning. I was advised to replace the Radiator Relay Switch.
I've just replaced my Radiator Fan Relay Switch. The problem I'm facing now is,once I connect my negative battery terminal,both the radiator and cooling fans starts running even before I switch the engine.
What could be the problem now??
Tqvm.
Old Apr 9, 2014 | 01:36 PM
bad fan relay its crap if U call your local dealer and have them run your vin it might be under a recall for that relay and no cost to you.
Old Jul 1, 2015 | 08:02 AM
jimmy154's Avatar
I have a similar problem.
Bought a new relay and they still don't turn on.
But I was told if I short pin #4 to negative battery terminal the fans should turn on, but they don't.
Is that true or should I go to the dealer and buy another relay?
Old Jul 3, 2015 | 03:07 AM
Huggy59's Avatar
Hi Jimmy154,
In my case,after all the trouble I went thru,the fault lies with the lack of the aircond gas.
I drove the car to an aircond shop and topped up the refrigerant and bingo,both the fan run well with intermittent.
Why dont you try that.
Old Jul 3, 2015 | 07:34 AM
jimmy154's Avatar
Originally Posted by Huggy59
Hi Jimmy154,
I drove the car to an aircond shop and topped up the refrigerant and bingo, both the fan run well with intermittent.
I think you got it, I'll try that.
But shouldn't they turn on when the thermostat reads hot also?
Is that what you mean by: "both the fan run well with intermittent."
chrysler2001
Dec 30, 2014 11:48 PM
bibi67
May 21, 2012 05:34 PM
ulyman
Aug 7, 2009 09:18 PM
colbertgang
Apr 26, 2009 09:30 PM
rcorbett
Dec 12, 2006 01:59 AM
