Radio Equalizer Lights Flashing
Old Jun 2, 2007 | 03:06 PM
niko's Avatar
Default Radio Equalizer Lights Flashing
I have 2001 T&C Ltd. After a jump start the radio is not working. Only the equalizer lights are flashing and the CD changer lights 1+2 and 3+4 are flashing alternately. There is no display nor sound. But illumination works. Any suggestions how to fix it? I tried disconnecting the battery without luck.
Old Jun 3, 2007 | 12:51 AM
Default RE: Radio Equalizer Lights Flashing
try to unplug your IOD fuse up front for 5 min if that did not do nething unplug your batt and hold the -and + together for 30 seconds and if that does not do nething either the radio or cd changer is messed up.
Old Dec 18, 2007 | 10:30 PM
pmalitas's Avatar
I have a 2001 Town & Country limited. While driving one day the computer console above went out and the odometer and stereo display also went out. It went back on after 10 minutes. I took it in for service and ever since then stereo displays are lit, cd lights go on then off after 10 seconds. Although the cd's do eject and cassette does also. You could change the station and the displays work fine, but the mainproblem of this allis no sound. All the fuses are fine. Do you folks think while getting serviced they disconnected the battery and I need a code for sound only. Another thing i noticed when i change the station from the steering wheel, I don't see the stations change on the display. Anybody go through this?
Old May 22, 2008 | 12:33 PM
john in jax's Avatar
Did you figure this one out yet?
I'm having the pretty much the same exact problem in my 2001 T&C Limited: equalizer lights are flashing, but the radio itself appears dead after having to put a battery charger on a low battery.
Old Jun 23, 2008 | 03:57 PM
BHOWARD's Avatar
I now have this problem along with the speedomtr not working. Took the thing to the dealership to get a window motor and regulator replaced and came back to me not working. Pulled the fuse and got the speedomtr working but still no radio. Could this be a trend here? Mine is also a 2001 T/C LXI with all the bells and whistles. Had no problems with it the day I took it to service and 2 hours later dead.
Old Jun 25, 2008 | 11:42 PM
woodsm's Avatar
Did any one get the answer to the problem with the EQ lights flashing? I have a 2001 T&C and the radio is doing the same thing after my battery died. Please help. The SN for the radio is T51ah1510g8040. Thanks
Old Jun 29, 2008 | 02:13 AM
BHOWARD's Avatar
I've decided to go ahead and find a used replacement for mine.For me personally this is just one of a long list of things to go wrong with my 2001.
Old Jul 3, 2008 | 01:46 AM
BHOWARD's Avatar
Was told yesterday that it is the BCM that has a problem- shows 7-9 codes, has been reset then shows 5 totally different codes.
F150
Dec 30, 2008 03:04 PM
gilbertb
Aug 6, 2007 10:02 PM
vivsor
Jun 4, 2007 04:59 PM
jstwhi1
Jan 7, 2007 08:00 PM
allan1010
Jun 19, 2006 06:40 AM
