rear brake help...
Old Apr 16, 2008 | 07:12 PM
jquinones's Avatar
Default rear brake help...
I'm sorry I know thats this is for Chrysler, but I need help. I post on Fordforum but no replys.
Hello guys,
I have 89 Aerostar ext and I need to change pads for rear brake, drum. And guy on Autozone ask me size 3 1/2" by 9" or 1 1/4"by 10" if I remmember right, and I try to remove thr drum by t woun't come out, it seems lose but won't come out, I need to take size on pads.
You guys have any idea how to take the drum out?
Thanks pros
Old Apr 17, 2008 | 03:29 PM
moe's Avatar
moe
Default RE: rear brake help...
you need to back off the adjuster.the drum has lip around it.from over time and wear.measure the diam of the drum that tells you what size you have.and then the sides.
Old Apr 17, 2008 | 05:05 PM
jquinones's Avatar
thanks
jquinones's Avatar
from Fordforum:
The shoes have probably worn a lip into the drum. You will need to pop out the little rubber oval plug on the back side of the backing plate. Then you will need 2 small flat tip screw drives to back off the brake adjusters. This will back the shoes off past the lip so that the drum will come off.
4everrunning
Jun 4, 2019 11:30 AM
StratLou
18
Mar 29, 2013 01:06 AM
CarComp
Jun 26, 2012 09:18 AM
velvet396
Aug 20, 2011 11:17 PM
3.3lxbluevan
9
Dec 10, 2010 07:17 PM
