Rear caliper piston retracting
Old May 5, 2018 | 10:01 PM
dgtc's Avatar
Default Rear caliper piston retracting
Troubleshooting a soft pedal issue, came to find the left rear caliper piston doesn't advance. When you push on the pedal the piston comes out but as you let go of the pedal it goes right back in. Couldn't advance the piston by pumping the pedal (pads removed).
So without thinking much, I replaced the caliper. The new one does exactly the same thing. I've not seen this before. What could be causing it?
The master cylinder is new also. No ABS or any other codes or light. Any help appreciated.
Damien123
Jul 24, 2017 12:02 AM
Ericbo101
Jan 7, 2017 02:45 PM
Okie
Dec 1, 2015 12:55 PM
andyb2000
9
Mar 9, 2012 08:49 AM
JP
Jul 8, 2006 08:21 AM
