Rear Driver's side bulb (blinker/brake element) keeps burning out about twice a year
Old Dec 9, 2020 | 08:57 PM
dana32cat's Avatar
Question Rear Driver's side bulb (blinker/brake element) keeps burning out about twice a year
Has anyone else ever had a problem with their rear driver's side turn signal/brake light going out on a relatively constant basis? The rear marker part of the bulb will still work, just not the blinker or brake element. I have a 2008 minivan that has had this problem since the beginning. Everybody kept telling me it's just a bad bulb, bulbs are so unpredictable, etc etc. I even had the dealership "look at it", tell me there was nothing wrong, and charge me to replace the bulb, blaming it on the bulb. Which made me mad because I've changed that bulb so many times I could do it in my sleep. I probably change the rear driver's blinker/brake bulb/marker bulb, on an average, every six months or so for the whole 12 years I have owned it. This last time I noticed it went out right after going through a car wash, which made me wonder if water has somehow been the culprit the whole time. The driver's rear light assembly looks just fine, no cracks or anything. Wiring on the bulb socket looks fine. Though the socket where the bulb plugs into is black around the top and turns into a rusty brown color, then to a cream/pea green color. I change the bulb and everything works again, until the next time, usually several months later. Has anybody else seen this problem? If so, any idea what might cause it?
Old Dec 10, 2020 | 04:27 AM
Have you measured the voltages in the bulb socket?
Old Dec 10, 2020 | 10:24 AM
dana32cat's Avatar
No, how would I do that? And would I compare those volts to the volts in the passenger rear light?
Old Dec 10, 2020 | 11:57 AM
You will need a simple volt meter. Connect the Neg prope to earth and the Pos probe to each of the bulb terminals. Shouldn't be much more than 12 volts.
Vonhofinvule
11
Apr 16, 2018 01:19 PM
tsousa71
Feb 15, 2015 09:27 AM
goggs
Mar 31, 2013 03:53 PM
BadJ77
Apr 23, 2012 08:35 AM
willem.spain
Mar 9, 2010 04:56 PM
