Removing Center Dash Bezel - 01 T&C
Old Nov 26, 2007 | 03:27 PM
71grande's Avatar
Default Removing Center Dash Bezel - 01 T&C
I wish to replace the radio and CD changer in my '01 Limited. What are the proper steps to removing the center panel bezel/trim, so I can get to both the main stereo/tape unit and the CD changer unit? I trust that there are several hidden screws and clips.
Old Nov 27, 2007 | 07:43 PM
Default RE: Removing Center Dash Bezel - 01 T&C
right above the cup holder is a cover the length of the cup holder remove it pops out.
2 screws hold the cup holder 2 hold the bezel u only need to take the 2 for the bezel out. The rest will pop off and disconnect the connectors for the AC and so on.
Old Nov 28, 2007 | 08:16 AM
moe's Avatar
moe
[ol][*]just like tech said.heres a picture of what your dealing with,moe[*]Remove cup holder.[*]Remove trim panel above cupholder by pulling straight out.[*]Remove center instrument panel trim panel.[*]Remove screws holding radio to instrument panel.[*]Pull radio rearward to gain access to the back of radio (RADIO).[*]Disconnect antenna cable from back of radio.[*]Remove bolt holding ground strap to the radio.[*]Disconnect the wire connectors from the back of the radio.[/ol]
Old Nov 28, 2007 | 03:21 PM
carr07uk's Avatar
is there not 2 svrews at the top u need to remove the caps ??
jmayarch1
Sep 20, 2010 01:33 AM
Michael Scott
Sep 3, 2010 10:49 PM
tommytwotoneitl
Sep 12, 2009 02:39 PM
TelecasterMan
Jan 10, 2009 01:54 PM
antares
Feb 12, 2008 07:26 PM
