rocker replacement now won't start
Old Dec 29, 2018 | 07:00 AM
airdbeck23's Avatar
Default rocker replacement now won't start
I replaced 2 rockers over the summer in my wife 2012 van, one in each head with no issues. Went back in last night to replace another because of the "tick". Replaced one in the front bank, took the back cover off to check the rear bank and all was tight. Went to start and it just cranks..... smells like its getting fuel but it won't start. Anyone have any ideas??
Old Dec 30, 2018 | 09:13 AM
airdbeck23's Avatar
Sorry I meant to say rocker arm replacement
Old Dec 31, 2018 | 04:32 AM
airdbeck23's Avatar
Ok. Had a buddy over today. Have voltage at coil packs and injectors. No fuses were blown and all the relays in the engine compartment worked. Went to advance to borrow their scanner. Have 4 codes that keep occurring.
P0108-MANIFOLD ABSOLUTE PRESSURE SENSOR CIRCUIT HIGH
P0113-INTAKE AIR TEMPERATURE SENSOR 1 CIRCUIT HIGH
P0123-THROTTLE POSITION SENSOR 1 CIRCUIT HIGH
P0222-THROTTLE POSITION SENSOR 2 CIRCUIT LOW
and this guy as well
U0416-IMPLAUSIBLE DATA RECEIVED FROM ESP
Any ideas on that U0416 code???
Old Dec 31, 2018 | 09:29 AM
REBEL59's Avatar
Did you recheck your work in reconnecting the various wire connectors? Sounds like even possible pinched wiring on your reassembly of things.As all those first codes are from things on the upper air plenum. The U0416 is from crazy interaction with thr TPS of the throttle body messing with the stability program which works with the throttle body! Check your engine wiring and get those first codes taken care of and I'll bet the U code goes away!
Old Dec 31, 2018 | 01:37 PM
airdbeck23's Avatar
I’ll check that when I get home. There were originally about 12 various codes but what you mention makes sense as those 4 will not clear.
Old Feb 25, 2019 | 07:46 PM
airdbeck23's Avatar
its been a while, tried a bunch of new sensors, checked timing, spark, compression. The link is a video I took using a spark tester, Ive never used one before but this spark seems rather slow and weak. Also didn't have compression in #6 cyl. and looking down through the intake valves I can see one of the exhaust valves is stuck open, ugh. Need to open up the valve cover again to see if the spring and or keeper in broken. Any thoughts on why my spark is the way it is?? I would think this should still start even with one cyl no compression.
Old Feb 25, 2019 | 08:16 PM
REBEL59's Avatar
Did you have the cam gears off to do the work you posted of?...If so, I guarantee the the motor is out of time and bent valve(s) and would prevent even rough running being out of proper timing component alignment.
Old Feb 25, 2019 | 08:20 PM
airdbeck23's Avatar
No i didnt mess with the cam gears. I checked timing and its dead nuts, just one out of the 2 exhaust valves is stuck open.
J0080
Aug 29, 2018 11:45 AM
shnormo
Mar 21, 2018 08:20 PM
Chris Hertling
Jul 14, 2014 07:05 AM
master tech
Apr 6, 2012 07:16 PM
Ryan L
Mar 29, 2012 06:26 AM
