rubbing noise in front end
Old Jan 24, 2007 | 02:57 AM
gaz440's Avatar
Default rubbing noise in front end
My 98 Voyager makes a rubbing noise on the right side when ever I turn left. Is this a sign of new bearings needed?
Old Jan 24, 2007 | 11:52 AM
Default RE: rubbing noise in front end
nope bearing noise is heard while driving and making turns with load on the bearing not rubbing. Inspect the area
Old Feb 21, 2007 | 11:29 AM
Tankity's Avatar
Check the sway bar link on that side. If the link breaks at the lower ball and socket joint, it will just hang there and rub on the tie rod, etc. as you turn into it.
Old Feb 21, 2007 | 02:37 PM
Jimbo Asprilla's Avatar
I had exactly the same problem last year with my Toyota Estima, it turned out to be a brake pad worn down to the metal.
Worth checking your pads just in case.
profyrfyter
Jul 13, 2013 01:30 PM
roadbandit
Mar 31, 2010 05:26 PM
deadfish9
Jun 10, 2009 06:57 PM
drake
Apr 12, 2006 11:07 PM
matune1
Jul 28, 2005 05:43 AM
