Shift Problem
Old Jun 5, 2013 | 05:51 PM
Quill's Avatar
Default Shift Problem
My friend has a problem with his 03. When driving it will suddenly seem to shift into neutral. The tach revs up and the speedometer, drops then it returns to normal. Sometimes it will do it once in a while other times it does it a lot. It not only startles you but jerks our backs hard. Any ideas? Thanks.
Old Jun 5, 2013 | 09:15 PM
chk fluid level check for codes in the computer
Old Jun 6, 2013 | 03:47 PM
Quill's Avatar
No codes for the trans, just an airbag light that has always been on.
Old Jun 6, 2013 | 04:53 PM
TimmyTim's Avatar
Lightbulb
I believe that there is a free recall on the airbag light by VOSA?...
Old Jun 6, 2013 | 08:25 PM
that recall is for 96-00 vans not an 03
Old Jun 7, 2013 | 02:05 PM
Raptor 07's Avatar
Can you elaborate on the speedo drop? If it's just decreasing as it normally should then disregard this. If it's droping 20-30 MPH or more in a second then you may have a fault in the output speed sensor circuit or the sensor itself. It is the signal source for the speedo and plays a big part in shift scheduling.
mta318
Sep 25, 2012 04:47 PM
OV10dude
Cirrus & Breeze
Jul 23, 2012 04:36 PM
hunterbaye
Jun 17, 2011 01:44 PM
cal60
May 26, 2007 08:29 PM
Rockstudio
Nov 18, 2005 06:28 PM
