Side Doors Not Opening
Old Feb 27, 2017 | 02:06 PM
ctjorourke's Avatar
Default Side Doors Not Opening
Hi Guys
I have just gone to my grand voyager 2009 model and tried opening the side doors, but they wont open either manually or via the remote, when i try the doors try to open (i can hear the motor whiring away but they start to pull out but its as if there is a security setting that stops them, i have turned the inside locks of so its not that, can anybody help ?
Regards
Chris.
Old Feb 27, 2017 | 05:05 PM
Raptor 07's Avatar
Inside locks meaning the pull up ***** on the doors and/or the lockout switch on the overhead console? If they are up and the switch disengaged try pulling the IOD fuse for 5 minutes in the TIPM (fuse box). This will reset the CAN data bus.
Old Feb 28, 2017 | 01:26 AM
ctjorourke's Avatar
Hi Raptor
Yes thats right although the inside door locks switch sideways not up and down and the overhead console switch is in the on position, i have tried every conceivable conbination on bothe the inside door locks and overhead console switch all tono avail, will try the iod fuse suggestion and see if that works.
Thanks for the suggestion
Chris.
Old Feb 28, 2017 | 02:40 AM
ctjorourke's Avatar
Hi All
Well what can i say just gone to car and tried to open doors and guess what they opened, this is without doing anything to try to fix the problem.
Old Feb 28, 2017 | 05:59 AM
andyb2000's Avatar
Hmm, that makes me think potential electrical problem, along the bottom of the doors in the guide is the plastic chain that houses the wiring, my guess would be the common broken wire in there causing it to fail to power the motor to move the door.
Remember there are two motors here, one is the lock/catch motor which unlocks and pops the door open slightly, then there is the main drive motor at the bottom of the door that moves and slides it back. My suspicion is you're hearing the lock motor work and it pops open, but the slide motor is either not running, slipping or has failed. That's where to look as my guess is they'll fail again soon!
If you search up the wires there are many repair guides as it's a common problem where the wires just age, crack and give up.
JaSonic
Mar 2, 2022 11:43 PM
nskeates
Jun 10, 2013 02:38 AM
kings322
Aug 7, 2011 05:55 PM
MemphisMom
Jun 12, 2009 02:55 PM
seth2278
Nov 16, 2008 09:52 PM
