sliding door stuck locked & liftgate won't stay open
Old Nov 9, 2017 | 07:40 AM
AprilBC's Avatar
Default sliding door stuck locked & liftgate won't stay open
2006 Town & Country:
1. Last week my drivers side sliding door got stuck in the locked position. I locked the van with the remote and now the door won't unlock manually or with the remote.
2. If I open my liftgate with the remote or inside car button, it raises but then closes automatically, even if I try to stop it from closing. If I open the gate manually, it will not stay open unless I hold it open.
Help!
Old Nov 9, 2017 | 07:53 AM
Scotsman4th's Avatar
Have you unlocked the side door and tried opening it from the inside and outside using the handles? I'd also try from the inside and put a little bit of pressure against the door, incase it is just stuck
For the tailgate, you might need new struts.
Old Nov 10, 2017 | 10:15 AM
AprilBC's Avatar
Default sliding door lock is stuck
The sliding door's lock is stuck in the locked position. I can't pull it up manually nor can I use the key or inside door unlock switch to pop it up.
Old Nov 10, 2017 | 02:42 PM
Just searched google, as you talk about pulling up manually. It's a different setup from my 2006.
This might help, I don't know if you can get the door panel off easily when the doors shut though.
3 Common Problems - Chrysler Town & Country
chrysler5569
Jan 6, 2015 07:45 AM
Lanatwo
Dec 13, 2014 05:40 AM
wdwrker1
Oct 7, 2011 07:20 AM
jaelli
Dec 2, 2007 10:39 AM
th_om_as
Dec 10, 2006 12:02 AM
