small problem after fitting new lambda sensor
Old Jan 16, 2016 | 06:39 AM
msd26129's Avatar
Default small problem after fitting new lambda sensor
so my engine management light has been on for over 18months due to a lambda sensor so i finally got it changed yesterday result no more light .. problem i have that wasn't there before is now when i come to a stop the car feels like its going to cut out and then revs up and starts hunting .. then after a while all is ok then again into the journey it does it again ..
sensor was bank 1 (front ) car is a uk spec GV 3.3 v6
could the mechanic have disturbed something as he said it was a bit of a pain getting to the sensor ..
thanks in advance
Old Jan 16, 2016 | 10:45 AM
Vmaxxer's Avatar
Maybe your computer needs a reset? (for example by disconnecting battery for 1/2 hour.)
At the other hand I had similiar problem with a mercedes with replaced lambda years ago, it seemend the car had a "selflearning" curve and it took several days before the car ran smoothly under all circumstances again.
Old Jan 16, 2016 | 02:49 PM
Your all most cutting out then reving sounds like a sticking throttle plate, MAF, where you need to clean it out with the magic spray. But my initial thought was to the Lambda sensor, where you have to have the right one for your engine made by the right manufacturer, otherwise you get problems. This has been highlighted on here many times.
Old Jan 18, 2016 | 07:09 AM
Just a little info on the Lambda. The Lambda controls the mixture at idle, so if your hunting is a very slight rev change at idle it is caused by the Lambda Sensor switching. Now if is a heavier hunt check your inlet system for air leaks and as I said clean out the throttle butterfly...
Old Jan 27, 2016 | 09:40 AM
msd26129's Avatar
just to let everyone no the problem has sorted itself out ..
Old Jan 27, 2016 | 02:12 PM
Looks like it has learned the ropes.
msd26129
Jul 10, 2015 02:54 AM
davoy
Oct 24, 2012 07:32 AM
rockrat
Jan 22, 2012 05:21 PM
pequeajim
Oct 7, 2009 11:45 PM
bigdenis
Oct 3, 2008 02:30 PM
