steering pump, oil seal
Old Apr 29, 2008 | 01:46 AM
I wonder's Avatar
Default steering pump, oil seal
extended weekend calls for some work on an old car.
as my steering pump is leaking oil on the main shaft, I'm going to try to replace the oil seal.
special chrysler tool for toothed gear I already have, but I would like to buy the seal before I start to work.
so, question is:
does anybody know proper dimensions for main shaft oil seal for steering pump.
car is voyager 2,4 liter gasoline from 1997 (with A/C, if that's important).
Old May 2, 2008 | 03:28 PM
I wonder's Avatar
Default RE: steering pump, oil seal
can't believe that nobody here never dismantled power steering pump.
so if you find yourself in that situation, you should know that there is a solution.
chrysler garage does not sell oil seal itself, but you can only buy the whole pump.
but it is possible to remove the plastic plate (the one that belt is running on) and exchange the oil seal only.
mine was a bit hard to find becouse of american measures, but I found it.
it's a 1 and 5/16 on outside and 19 mm on the inside oil seal.
no more oil leak on the pump shaft.
grand zyo
Sep 5, 2018 12:14 PM
Darth Menace
Feb 19, 2016 09:16 PM
milesy_boy
11
Nov 19, 2009 05:34 PM
petewxm
11
Aug 2, 2009 01:23 AM
IceBoy
Dec 5, 2007 01:46 PM
