Town and country ABS issue
Old Sep 13, 2016 | 08:55 PM
BAMF224's Avatar
Default Town and country ABS issue
I have an 08 town and country 3.5l. Recently sometimes when i hit a bump just right the abs and etc light comes on for a minute then goes off. Is there a particular sensor I should look at by chance
Old Sep 14, 2016 | 12:00 AM
I would get a good scanner and see exactly which one it is by pulling the codes.
Old Sep 19, 2016 | 08:11 AM
Leedsman's Avatar
Some time ago, if that model uses the same arrangement as mine (2006), it's useful to clean out the cogwheels that actuate the sensor on each wheel. They get clogged with rust and general crud. The rust spoils the magnetic signal to the magnetodiodes in the sensors, so much so it could be on the verge of not working properly.
Use a small wire brush together with a screwdriver to shift stubborn rust. Both kinds of rust (Fe2O3 and Fe3O2) are magnetic. The target is to have the cogs clean and sharp, there is no need to use anti-rust such as Jenolite.
This is a time consuming job, but it is straightforward and costs nothing, and at least eliminates one cause.
Caution: When jacking, see that an additional prop is used together with the jack for safety's sake. I just put the wheel I've taken off under the body near the jack plus a bit of board to be on the safe side.
Leedsman.
Old Mar 31, 2017 | 09:50 AM
Modelwise's Avatar
Default Chrysler voyager 02 paint abs pump
Leedsman.
can you help were about is the abs pump need to look at the wires to it looking at my engine can see the brake servo on the firewall were about would it be many thanks Alistair
jimmy154
Dec 14, 2019 09:45 PM
Pop45
Feb 15, 2014 09:21 PM
dc_tr
11
Jan 3, 2010 05:39 PM
T&C2009
Mar 14, 2009 10:39 PM
mrbradva
Oct 15, 2007 08:50 PM
