Town and Country driver heated seat not working
Old Jan 7, 2018 | 12:41 PM
Crc13SG's Avatar
Default Town and Country driver heated seat not working
2014 Town and Country 30th anniversary edition
25K miles
Hey guys, newbie to the forum here. I’m having issues with my wife’s Town and Country’s driver side heated seat. Most of the time when I turn it on, it remains on for 2 seconds and then shuts off. Every once and a while it will stay on. I’ve checked the connections under the seat. Unplugged them and plugged them back in and didn’t help any. Any insight on this problem would be greatly appreciated!
Thanks in advance!
Old Jan 7, 2018 | 12:53 PM
There was a thread on this problem last month https://www.chryslerforum.com/forum/...working-28625/
Old Dec 12, 2018 | 05:36 PM
Josh Handschuh's Avatar
Default Get it fixed?
I’m having the same issue I’m just wondering if you were able to figure out what it was
Old Dec 26, 2018 | 07:52 PM
Crc13SG's Avatar
No I have not found a fix yet. I’ve just been tolerating it until I get it into a shop to have it looked at. The dealer wants like $150 just for the initial cost to bring it in and look into it. Parts and labor on top of that.
Old Oct 4, 2021 | 02:24 PM
Robin Side's Avatar
Default seat heater
I was having problem with heated set in chrysler town and country. It would heat up if I was not in the seat, turn off within seconds of turning on when I was in it. My husband helped me to trouble shoot. This might be worth a try: there is a small black junction (?) box in the front, under the driver's seat. This plugs in to a larger black box. We "unplugged" this (had to pinch the sides to slide out) and then put it back in. This seemed to work. Also jiggling this connection is also what worked for us. Worth a try!
Old Jan 3, 2022 | 05:03 AM
joel b's Avatar
Morning Alan
I believe i figured out what was the issue, So i think someone left the driver side window down in a rain storm seat got soaked water got into the heated seat module and corroded the tiny contacts, I used a mini file cleaned the contacts shot electrical cleaner thru both the module and plugs also super mini wire brush to clean plugs, put it back together, everything it working perfect for now ....
thank you for sending me in the right direction you saved me alot of $$$
joel b
Old Jan 3, 2022 | 05:09 AM
@joel b, thanks for the update.
cyborg50
Mar 22, 2018 06:56 PM
Zanders Customs
Feb 7, 2017 11:03 AM
Ericbo101
Jan 7, 2017 02:45 PM
minimonster17
Mar 16, 2015 10:41 AM
mad12.1964
Feb 28, 2011 03:09 PM
