trans fluid check ?
Old Feb 19, 2012 | 09:27 AM
Joe C's Avatar
Default trans fluid check ?
2010 town and country, how do you check the trans fluid? 31,000 mi leaving on vacation just want to check fluid level, thanks, joe.
Old Feb 19, 2012 | 12:03 PM
pestilance's Avatar
start the car and let it idle in park,pull the dipstick out of the tranny filler,and check the marking for cold or hot,should be between the 2 holes for cold or hot,
if u are starting from cold then will be the cold section,if u are just back from a run will be in the hot section.
pull the stick and wipe it clean,then put back in pull it out and check the lvl
Old Feb 19, 2012 | 02:24 PM
booke23's Avatar
Best to do it when it's fully up to temperature using the Hot marks on the dipstick. The mark on the dipstick for cold is only accurate when the fluid is exactly 72 F and there is no way of knowing this.
aggiejet
Jun 30, 2012 03:22 PM
parlayjay
Apr 18, 2010 03:28 AM
Pacifica3.82007
Feb 26, 2009 08:16 PM
SDHUSKER
Nov 20, 2007 11:36 PM
tmp03tnc
Sep 21, 2006 07:24 PM
