Transmission Fluid Change Advice
Old Oct 19, 2020 | 12:00 PM
da5id403's Avatar
Default Transmission Fluid Change Advice
I own a 2003 Chrysler T & C with 30,000 original miles. I am not having any problems with the transmission and would like to stay that way. But I do recognize that the fluid in the transmission is 17 years old. Should I change it? Power flush? I am reluctant on the power flush because my vehicle leaks no fluids and I have heard that power flush can mess with the seals. Any other recommendations for maintenance of a 17-year-old vehicle with no problems will be appreciated. Thanks.
Old Oct 19, 2020 | 12:37 PM
new filter Chrysler rtv as the gasket 5 qts of ATF+4
Old Oct 22, 2020 | 04:55 PM
da5id403's Avatar
This is a little cryptic. If I take it to Firestone they will understand it? Thanks very much.
Old Oct 23, 2020 | 11:22 AM
ggoose's Avatar
Make certain Firestone (or any repair shop) will use ATF+4 and not anything else with snake-oil added (aka LubeGard). Despite what anyone claims or says, it is not the same. If there is any doubt, make them show you the atf+4 bottles as it does not come in a big barrel. Not using atf+4 will likely cause you problems 1-2 years down the road as the lubegard wears out.
Old Oct 24, 2020 | 12:08 PM
da5id403's Avatar
Thank you, I will do that.
Zweifel
Oct 10, 2020 11:22 AM
aggiejet
Jun 30, 2012 03:22 PM
jake763
Jul 17, 2009 02:08 AM
kgillespie
Mar 19, 2009 06:34 PM
mrorange
May 23, 2008 09:42 PM
