Vapor coming out of air vent
Old Jun 29, 2007 | 10:39 AM
Booker's Avatar
Default Vapor coming out of air vent
I've been driving without my fan resistor for about two weeks. When I have the fan blowing on high everything works ok. However, several times when I was using the air conditioning without the highspeed fan onvapor came out of the airvents. As soon as I turned the high speed fan on the vaporwould go away. The air never stopped working, it seems to be cooling ok.
Do I have a problem developing? In the past vapor always meant the coil was leaking. Or is it related to only having the high speed fan?
Thank you,
Booker
Old Jun 29, 2007 | 01:06 PM
Default RE: Vapor coming out of air vent
what year and engine size?
Old Jun 29, 2007 | 01:52 PM
Booker's Avatar
2002 3.3L
Old Jun 29, 2007 | 04:11 PM
possable evap temp sensor not telling pcm that the evap is freezing, Low freeon, water build up inside hvac housing.
Old Jun 30, 2007 | 06:59 AM
Booker's Avatar
So is my next step to have the freon recharged? Or something else?
Old Jun 30, 2007 | 10:11 AM
which ever is easy for u to do have some one check the freeon fill a dual system should be 2.69 or 2.88 lbs of freeon.
Old Aug 18, 2007 | 06:33 AM
volly's Avatar
I had a 2000 Caravan that did the same thing for years. Is your air set to inside or outside source? Depending on humidity levels outside it could be as simple a high humid air being cooled, and you seeing it like a cloud. Change your air to inside source and see what happens. I bet it will stop.
Mudslinger72315
Aug 16, 2017 03:50 PM
Crazcnuk
Dec 19, 2014 09:14 PM
Chrysler Forum Editor
Feb 7, 2014 01:18 PM
MBarnett86
Dec 3, 2011 02:05 PM
appleroma
Nov 11, 2009 05:04 PM
