voyager 2.5 non start
Old Jul 14, 2010 | 03:18 PM
andrew's Avatar
Default voyager 2.5 non start
can any one help i have a2005 voyager 2.5 crd it started losing power when driving and now it will not start .with the fuel injector pipes craked off there is very little diesel.there is alson very little diesel being supplied to high pressure pump
Old Jul 14, 2010 | 03:37 PM
Merlin's Avatar
You should be very careful on cracking off the fuel lines the fuel can be around 2000 PSI and that injected into your skin can kill you. Safety tip over with, it is normal for only a little amount of fuel to come out at cranking. I would do a search on here for P1130 as the info in that will help you.
Old Jul 15, 2010 | 03:38 PM
andrew's Avatar
thanks for your reply.checked fuel filter underneath and found it to be dry of diesel.with ignition on the low pressure lift pump on fuel filter housing runs all the time.i checked fuel tanki and although it was reading fuel in tank there was not.i put twenty pounds of fuel init cleared fault codes down and the engine started.drove on a run ok and re scanned and found no fault codes in memory but with the engine off and ignition on the low pressure fuel pump runs all the time is this normal.tomorrow i am going to do a injector leak check.
thanks andrew
John Norrish
Mar 11, 2016 01:34 AM
nickaday
34
Jun 9, 2013 03:51 PM
Audrey Duffield
Feb 17, 2013 03:10 AM
jtmattison
Oct 26, 2011 12:39 AM
mcs350
Oct 25, 2010 03:30 PM
