Voyager 2010 no brake light
Old May 5, 2024 | 06:55 AM
Titi's Avatar
Default Voyager 2010 no brake light
Hi,
I have a 2010 Voyager and there is no brake light when I push the brake pedal.
No light at all during the day, but when night is coming the light in the middle of the back glass is working when I push the pedal (note that only this light is up, nothing on the right or left side appears).
1- I checked the bulbs on both sides and they are all right.
2- I checked all the fuses in the fuse box and they are ok
- I guess the brake switch is ok since I can get it working when the night is arrived. Except if there is a special contact in this switch for rear lights.
- Why the rear middle light is working only during night ? I have tried simulating night putting a cache on the dash board (detector in the middle on the top of the dash board) with no success, even the back glass light is not working.
So now I do not know what to check.
Is there any junction boxes to check? Or any other module?
If anybody may have an idea that would be really appreciated.
Thanks a lot,
Bruno
Old May 5, 2024 | 11:35 AM
ggoose's Avatar
My suspicion would be a poor/corroded ground. Suggest posting on 'chryslerminivan.net'; a very knowledgeable group.
Old May 8, 2024 | 04:59 AM
Titi's Avatar
Thanks for your suggestion: it was a poor/corroded connection.
I fixed the problem for two of the three lights : I cleaned the connector behind the assembly as well as in the bulb holders, they seemed clean but I guess that something was corroded somewhere.
Moreover, one the two bulbs was visually correct (both filaments seemed new), but in reality there was a discontinuity inside the bulb (in te base?) for one filament. I changed the bulb and it was ok.
So the only problem remaining is the rear middle light which only works at night.
Old Jan 28, 2025 | 04:25 AM
Titi's Avatar
About the rear middle light, I solved the problem by replacing the rear center light assembly.
I thought the light was good because when I looked for the fault it was in the evening, and at night the lamp was fine.
After checking all the points of the circuit, I finally decided to change the assembly light and now it works correctly.
I don't know what was wrong, but maybe there was a component in the rear assembly light that was sensitive to humidity, temperature or brightness?
monsterdub
May 5, 2024 11:10 AM
4everrunning
Jun 4, 2019 11:30 AM
OGHBEICA8
Dec 9, 2011 04:43 PM
mikeb223
Mar 28, 2011 03:23 AM
bcmf
Sep 20, 2010 05:36 AM
