Voyager -96 starts sometimes
Old May 22, 2010 | 07:23 AM
ansod's Avatar
Default Voyager -96 starts sometimes
The fulepump only starts sometimes, and if it starts it stops runing after a few minutes. The pump itself seems to be ok!
Old May 22, 2010 | 02:58 PM
ok so whats the question?
Old May 23, 2010 | 04:49 AM
ansod's Avatar
Default The question
Well, something most be wrong and I need to know what. I can't use the car right now. So the question is: What can be wrong and what can I do?
Old May 23, 2010 | 08:56 AM
if U have no clue about what U are doing or have no tools to figure this out I would let a professional take care of it. This forum is for people that can at least tinker with things and have a mechanical mind set.
Old May 23, 2010 | 01:36 PM
ansod's Avatar
ASD-system ok.
Fuelpump relay ok.
Wiring ok.
Fuelpump is removed for cleaning and control. I don't got the vcalues for this specifik pump but thats not a big problem. But the question remains. Have I missed anything. I'm not that good att english so it's rather difficult to explain things sometimes.
Old May 23, 2010 | 09:22 PM
if the 2 relays and the wires are ok ten that leads to just the fuel pump itself is bad.
Can u jump the fuel pump relay and get power to the pump?
Old May 24, 2010 | 12:07 AM
ansod's Avatar
Yes, i've done that. The pump goes slover and slover and then it stops. Sounds like it works heavier and heavier. I'll see if I can clean the inside. If that doesn't have any effect I suppose that I nedd a new pump/pumpmotor. Do you know the electric impedans of the pumpmotor?
Thanyou for your patience - it might be esyer if you learn swedish!
Old May 24, 2010 | 07:52 AM
replace the whole pump assembly
Old May 24, 2010 | 10:45 AM
ansod's Avatar
I'll do that tomorrow. Today I took out the pum,p from the pump modul and I gess that the coil (?) is broken. I'll get back after replacing tomorrow.
bryamon
Aug 17, 2019 12:54 PM
nectis
13
Mar 6, 2014 05:42 PM
altewalde
Dec 10, 2012 08:14 PM
tmerila
Aug 28, 2009 02:45 AM
roughyear
Feb 19, 2006 12:33 AM
