what happen if spark plug...
Old Mar 25, 2008 | 08:42 PM
jquinones's Avatar
Default what happen if spark plug...
hello guys!
what happen if spark plugs need to be change?
can I see any diference on function of the car if spark plug need be change?
thanks guys
Old Mar 25, 2008 | 08:48 PM
tntandc's Avatar
Default RE: what happen if spark plug...
My T&C 3.8L just turned 103k. We had the plugs replaced @ 101k and it runs alot smoother and a1-2 miles per gallon boost. Had dealer do it @ $199.00 (plugs and wires). Not worth trying to reach the back ones in my opinion.
Old Mar 26, 2008 | 02:48 AM
I wonder's Avatar
ORIGINAL: jquinones
hello guys!
thanks guys
with old plugs, chances for missfire are a lot bigger.
also, you put an extra strain on ignition system, becouse old plug requires higher voltage to fire a spark.
no special improvements with new plugs (if they are not too old). you may get a smoother idle. real difference is on higher engine revs.
great improvement that tntandc got from changing wires and plugs is becouse his old ones were pretty old.
Old Mar 26, 2008 | 05:51 PM
jquinones's Avatar
I'm asking because my Ford Aerostar start to chock when I start the car, even when its worm, when I'm driving at 45 miles it does too, like chocking. DO you think its spark plugs?
Old Mar 27, 2008 | 02:43 AM
I wonder's Avatar
I don't think so.
if it's an ignition problem (assuming that fuel supply is OK) than it's becouse of plug wires, not plugs them selves.
Old Mar 27, 2008 | 04:30 PM
jquinones's Avatar
I did make a tune-up myself 2 years ago!! maybe wire just loose?
Ill check and let you know
thanks
any more ideas of anyone?
thanks guys
Old Mar 28, 2008 | 02:45 AM
I wonder's Avatar
spark plugs would make this kind of problems only if they were very old and full of debrie.
but, you can see that if you take them out for inspection.
consult your dealer and see when do they need replacement.
becouse of irratic missfire, my guess is still plug cables.
emhomes
Jan 19, 2014 05:42 AM
ragrelo
Jun 1, 2010 01:25 PM
Sparkplugs.com
Dec 1, 2006 02:56 PM
Emersive Audio Video
Jul 3, 2005 08:33 PM
