Whats correct engine ide speed for 2.5 CRD
Old Jan 13, 2015 | 08:50 AM
darkcild101's Avatar
Default Whats correct engine ide speed for 2.5 CRD
I think my idle engine speed is set too high. Its close to 1000rpm and when i drive off and put the gear into 2 and in slow traffici have to continuously brake as the car moves too quickly without me even touching the accelerator. Like the revs are rather high for that gear if i make sense
How many revs should it do in idle/neutral
Cheers
Old Jan 13, 2015 | 10:06 AM
tfb's Avatar
tfb
Can't find the exact figure, but it should be between 790 and 870 RPM (worked out from some of the requirements of diagnostic tests)
Regards
Richard
Old Jan 13, 2015 | 10:34 AM
Regards
Richard
Thanks. i will try get my exact one tonight. is it possble that idle has been adjusted higher than normal and if thats the case can that cause over fueling at start up?
Old Jan 13, 2015 | 01:24 PM
tfb's Avatar
tfb
The idle speed can't really be adjusted, it's a software function and not a screw like in the old days.
Not sure if it could be caused by the accelerator pedal not fully returning to rest though.
Regards
Richard
Old Jan 13, 2015 | 02:05 PM
Vmaxxer's Avatar
My 2002 2.5CRD runs idle at ~900
Old Jan 13, 2015 | 03:06 PM
Mine just below 1000
Attached Thumbnails Whats correct engine ide speed for 2.5 CRD-20150113_202205.jpg
Old Jan 13, 2015 | 03:13 PM
Cheers
- why 2 ?
- your RPM is correct for an automatic
Old Jan 13, 2015 | 03:16 PM
Originally Posted by QinteQ
- why 2 ?
My car is a manual sir. Number 2 because its an old habit I always drive away in gear 2
Old Jan 13, 2015 | 05:24 PM
Vmaxxer's Avatar
I remember I have a shot of my idle rev (also manual)
BTW I also used had the habit to drive away in gear 2 with manual diesel engines but I found it was not the proper way with the heavy weight of the Voyager. With heavy cars like this you really need to use the 1st gear, especially with a little cargo in it.
Attached Thumbnails Whats correct engine ide speed for 2.5 CRD-2015-01-11-21.58.59-1.jpg
Old Jan 13, 2015 | 05:41 PM
Noted. I will desist from starting off in 2nd use 1st. I wish this lovely car was an automatic
