Will a code reader identify why my pollution light is on?
Old Apr 15, 2010 | 08:02 AM
Gray06TCmb's Avatar
Default Will a code reader identify why my pollution light is on?
2006 T & C. Pollution light came on at 33K miles (not flashing).
I hope AutoZone will plug in a code reader for me ..If not, may buy one.
Anyone know the MOST LIKELY CAUSE for this? That is, the actual component needing attention.
Old Apr 15, 2010 | 03:15 PM
it will tell u what the codes are yes what to fix no that is where a trained tech comes into play.
Old Apr 15, 2010 | 05:28 PM
glowplug's Avatar
You can get the codes by turning the car on and off three times
e.g. off-on off-on off-on.
Your trip meter will then deisplay the relevant P codes e.g. P1130. You can correlate this against the list of codes whih can easily be found on the internet.
Old Apr 15, 2010 | 06:14 PM
huasi87's Avatar
actually the trick is move the key between ACC and ON three times
ACC-ON/ ON-ACC/ ACC-ON
EVIC will show codes to you and then you can search for the codes resulted
usually codes are not addressing the real problem but like 40% you will get a code explanation that is directly hits your problem.
remember that if you got a massive amount of codes that seams Irrelevant to your problem then you might have a serious problem or a very silly cheap to fix problem
Randy L
Jun 23, 2016 05:28 PM
Newtonn
Nov 12, 2013 03:09 PM
QinteQ
14
Apr 12, 2012 01:19 PM
razerlaff
Sep 17, 2010 11:46 AM
scoobygeorge
Nov 23, 2008 07:00 AM
