window
Old Mar 18, 2007 | 01:38 PM
chrysler34's Avatar
Default window
my drvier side window is stuck and it used to go up and down then get stuck then it stoped all together need help thanx
Old Mar 18, 2007 | 03:33 PM
Default RE: window
new motor and regulator
Old Mar 19, 2007 | 07:01 PM
pl510's Avatar
Default RE: window
It is a small posibility that if you can get to the motor and give it a (shock)tap it with a tool of some sort , Just enough to dislodge stuck brushes in motor it may help, I have similar problem before, doesn't hurt to try , and there is nothing to loose except about an hour of your time.
Old Mar 19, 2007 | 07:54 PM
Default RE: window
if its in the full up then dont mess with it if its down then yeah beat on the side of the door panel and get it back up once up dont mess with it
Old Mar 31, 2007 | 12:36 PM
bonner63's Avatar
Default RE: window
I had same problem - would work intermittently and later only when I gave the door a sharp hit with my hand. Then it stopped altogether- quoted for new motor & regulator in Australia was AU$580- so decided to have a closer look. Took door panel trim off and removed 3 screws holding motor to door panel. Then undid 2 screws holding the motor cover to the regulator. There I coud see the problem- the brushes could not move any more as the wire braid to the brushes was stopping any more movement of brushes. I simply removed the brushes and used a small drill to make the slots longer for the braid to slide in the plastic guide. This gave an extra 1/16th inch of movement for the brushes to contact the armature and works a treat. Should give it another 4 or 5 years and then I'll look for new brushes.
wmcleod
Feb 1, 2006 10:30 PM
71grande
Nov 18, 2005 08:51 AM
madsabre
Nov 2, 2005 03:23 PM
QAA
Sep 24, 2005 07:40 PM
aleatha_0814
May 11, 2005 01:58 AM
