Window works then doesnt!
Old Nov 4, 2009 | 09:39 AM
duffer's Avatar
Default Window works then doesnt!
Drivers side window works then doesnt! it is not the fuse and the motor is still trying to move as the interior lights dim when the switch is activated ...Any ideas guys??
Old Nov 5, 2009 | 02:54 PM
pete3000's Avatar
Old Nov 7, 2009 | 07:04 PM
22chrysler's Avatar
Yes, I have a lot of ideas. You probably have a motor that's starting to fail, or a switch problem or something else.
Old Nov 14, 2009 | 02:11 PM
voyager_dan's Avatar
it will be the motor when mine started doing this i took the motor apart 2 screws then the top comes off showing the winding remove the winding and clean the track with some fine wet and dry in the end i replaced the brushes which i robbed from a motor at the scrap yard
Old Nov 15, 2009 | 06:24 AM
duffer's Avatar
cheers dan . got er sorted!!
chriswest
Mar 12, 2009 08:55 PM
jsantana2490
Feb 7, 2009 09:15 PM
alparsalan
Feb 22, 2008 10:46 AM
powers84
Jan 6, 2008 05:50 PM
powers84
Jan 6, 2008 05:48 PM
