Window works then doesnt!
Drivers side window works then doesnt! it is not the fuse and the motor is still trying to move as the interior lights dim when the switch is activated ...Any ideas guys??
Yes, I have a lot of ideas. You probably have a motor that's starting to fail, or a switch problem or something else.
it will be the motor when mine started doing this i took the motor apart 2 screws then the top comes off showing the winding remove the winding and clean the track with some fine wet and dry in the end i replaced the brushes which i robbed from a motor at the scrap yard
