Wipers not functioning properly
Old Feb 26, 2016 | 10:38 AM
MOSSBARGERS's Avatar
Default Wipers not functioning properly
Issue: Wipers not functioning properly (2013 T&C)
Hoping someone has come across this problem and has afix:
  • Wipers will not park – they stop right wherethey are at on the windshield when the switch is turned off
  • All intermittent settings do not functioncorrectly – no time delay, all on continuous slow speed
Slow and fast settings work fine
Replaced multi-switch with new MOPAR unit – no change
Disconnected cable to multi-switch and took the followingreadings:
Engine off: red/green wire 0 ,white/green wire 12v, red wire 12v, black wire 0
Accessory switch on: r/g 75 Ω, w/g 8v,r 12v, b 0 Ω
Engine on: r/g 14v, w/g 9v, r 14v, b ∞Ω
TIPM M13 & M15 fuses are OK.
Any help would be greatly appreciated.
Old Feb 26, 2016 | 11:32 PM
the tipm and front control module is the actual control unit for the wipers.
Old Feb 27, 2016 | 08:56 AM
I figured it would be either the multi-switch, TIPM or the wire harness.
Is there a particular part in the TIPM that I should be looking for other than fuses?
Old Feb 27, 2016 | 04:40 PM
Post by Andy [much older GV] might give insight. Always worth a look under the gremlins lid, yours is a bit young for wire cancer and verdigris so try wiring, relays 1st. Best of luck.
bpress54
Mar 31, 2014 12:14 PM
earleb
Feb 14, 2014 03:07 PM
Huggy59
Dec 24, 2013 10:56 AM
Contact
Mar 1, 2013 07:56 AM
44ark
Apr 4, 2012 05:38 AM
