wrong oil filter
Old Aug 28, 2010 | 11:18 PM
marcusamaura's Avatar
Question wrong oil filter
ok so i got an oik filter and didnt tell the parts store it was a voyager lx(or whatever) the oil change was done and my boyfriend drove about 15 blocks.(to the store and back).he said it was knocking a little bit..if we get the right filter and some more oil will it be ok? or am i screwed??
Old Aug 30, 2010 | 11:37 AM
United1's Avatar
Well, I would first find out the difference between what you installed and what you should have (full full, drain back, etc). Many of the filters are very similar in design, but vary on size, volume, etc. You can go online to check what you should have and compare it to the specs of what you installed. I find it even more toubling that you were able to buy a filter from some parts store without the sales person verifying the model and engine size. Also, was the correct oil viscosity and volume used? If it is knocking due to an oil issue, that is not good. Post some more info and we can provide a more definitive opinion.
08retract
May 7, 2011 08:05 PM
Carlo60
Apr 7, 2011 03:45 PM
bnamassey
Jun 24, 2010 07:12 AM
i need help
Cirrus & Breeze
Mar 24, 2007 05:25 PM
Broken
Feb 18, 2007 01:45 AM
